Wow no one has added an oil pressure gauge using a VDO sender with stock threads for the warning light and gauge I'm shocked. Well I'm going for it and I will post back with the results.
Sorry, mine is a mechanical oil pressure gauge, so the stock electrical set-up is in tack.
I don't believe there is enough room for that sender unit you are talking about in this link because of the secondary air pump.Thank you for the link I was trying to avoid using the relocation kit by using this
Pressure Sender- M10x1K
