Ok so I have a 2000 NB 1.8L Turbo that I am converting to all-electric. So this vehicle will have no mechanical engine and using the existing transmission to run the vehicle. We removed the engine and everything else. Only thing we are stuck on is the fuel filler tube. We cut the tube running to the gas tank so it is free on the bottom. But we also tried to cut the top of the filler tube on both sides to see if it will drop. It is pretty loose and I have a feeling we are close but the only other option I have is to remove the rear passenger fender. So I was wondering if there is a way to remove the filler tube without removing the rear fender. Thanks!
