Where can I get 13-20mm spacers and necessary hardware?
Yikes! Hope everything is OK. Your reply is the reason I have not jumped on the 'wheel spacer' bandwagon.1of24in2k1 said:i'm running 10mm f and 20mm in the back, h&r trak+
the ecstuning bolt will not hold!,
ecs... send me their bolt and my wheel came lose, almost got kill.... fyi if you use H&R spacers, use H&R bolt.
anyway keep checking the bolts when running spacers.
Thats another very good reason too!!! Tire cutting could be added....noR said:if you need more reasons, how about bearing abuse?
wheel spacer bandwagon? Wheel spacers can be an integral part of Wheel fitment. Using the correct length hardware is imperative. Fail to do this and safety is in question.Yikes! Hope everything is OK. Your reply is the reason I have not jumped on the 'wheel spacer' bandwagon.
