1 - 10 of 10 Posts
So as far as i know the engine is airtight ?
In some engines you never need to top up the oil, like my brothers RS6
Yet in mine i need to top up every 2 months or so.
Just wondered where it goes ?
Is it burn't off ? Or ?
Some cars engines are just heavier drinkers than others, kinda' like people. Seems when they have problems they drink more. If you know what I mean. ;)
Basically, the oil gets around the pistons and is burnt off; if there was NO clearance between the piston and the cylinder wall, they could not move. If you want to know more about oil consumption, here is a good read -
Vehicle Oil Consumption, Why's & Wherefores
and another -
Engine Oil Consumption
M.
VAG, it's a lifestyle...
I was going to be a smartass and say "under the 710 cap", but I guess that's not what you were asking;):p
Do you have a 2.0L; could it possibly be the ring issue that many have had? Here in the states; many had the dealer ok a re-ring job (if the oil went beyond the oil consumption test) and that seemed to fix most people's issues. If thats the case; I guess the oil was going past the rings, getting burned in the cylinders and going out the exhaust!
Here is a link; discussing the issue:
http://forums.vwvortex.com/showthread.php?574779-Oil-Consumption-Fix-for-2.0L!-(semi-repost)
:roflmao:, he would have had that coming!
Btw, Blugg doesn't say how many miles, just every two months... ???
And he doesn't say what a "top up" is. A litre?
710 cap would of fallen on dumb ears, must be a U.S. term :)
4,000 miles is 2 months. It's either half way down the # marker or just over it. But yes a litre top up. Is there much difference between the oils ? I know i have to use diesel oil. Cheapest $22 a litre, but there are some that are $38 and $46 going with $2 to the £1 :)
lol, take 710 and rotate 180 degrees;):D
That may not help, he's on the wrong side of the pond!
Blugg... 7I0... turn your computer screen upside down... 0IL.
1 - 10 of 10 Posts
