tsuter said:
That's a problem. You got 1000s of good threads and just dumped not only them .... but your users...links pictures.
What a waste.
I'd figure it out if I were you...
In the meantime, I'll be over here...
http://forums.vwvortex.com/zeroforum?id=27
Good luck...
Yes I agree it is a problem, however it was one without a solution, I spent the better part of a year trying to fix the old database so that we could import the information into this rendition of the newbeetle.org.
However that just was not possible, you can still view that information at
http://forums.newbeetle.org and you can still search the information, you can use the information.
You can do whatever you want, if that means you are leaving the site to head over to the VWVortex, then it has been nice having you here and I hope you stop by again in 6 months when the information from the old forum has worked its way over here naturally.
With the same posters here, it will not take long for the photos, links and threads to be recreated.
Best of luck.
James
