Where exactly is the fuel filter/ water separator on the '06 1.9? I haven't bought any books yet and would like to find the unit not only on my '06 1.9 but my parent's '04 1.9. Thanks...Michael P.
overwhelmed/underpaid
It's at the bottom of the fuel filter, which is located right by your washer fluid tank. You'll see it; it's got 2 lines and a T-fitting. Undo the clamp on the housing, pull the filter up, and twist the knob and drain for a few seconds. That's all there is to it.
180 Degrees out of faze
Be very careful. That plastic knob on the bottom is very tender. Twist too hard, and you will have to buy a new fuel filter. Just twist gently. Don't give it that one little bit more twist to be sure it is tight.
Here-here!
If that plastic knob breaks..you get air in your fuel system which means your car will not turn over and you might think the injector pump has gone out. I speak from experience. My situation though was because someone rocked it into place when they were replacing it...broke the connection just enough to allow air in. I ended up being towed to the dealership because I had no idea what was going on.
