180 Degrees out of faze
Sorry, no photos at the moment.
If you are standing in front of the car, it will be in the upper radiator hose on the right side. Look just to the left of the air box. It will have a wire cable attached. To remove, take off the wire cable. Then pull the spring clip out to the side. DO NOT DROP the spring clip. Then just pull the sensor up and out. Make sure the rubber O ring is also removed.
