Hi everyone...need some help here.
I have a 2002 1.8T with around 130,000 miles. A couple weeks ago the waterpump went out while driving. I immediately pulled over and turned the car off. I didn't drive it any longer. There was NO smoke out of the exhaust at this time, and after I was towed home it ran fine when idling for a few seconds (of course not letting it get hot).
I ordered the waterpump/timing belt kit from ECS and changed the waterpump, timing belt, tensioner, thermostat, housing, serpentine belt, etc...also flushed with new G12 coolant.
Started up fine. No codes. No noticable smoking. Drove to AutoZone for new oil and in the rearview mirror noticed a large amount of white smoke. Never noticed any smoking before this.
Car is now smoking white smoke, but runs good. Losing coolant very quickly in the reservoir. No external leaks can be seen. No oil in the coolant, no coolant in the oil. But again, lots of white smoke along with loss of coolant. No red flashing light, engine temperature is fine.
Sounds like a head gasket, right?
BUT...compression is GREAT. Compression test shows all cylinders between 175-185. They hold steady pressure; none leak down fast. Stand alone leak-down test has been done yet.
Granted, I have NOT done the proper burping procedure to get out any possible air pockets. But air pockets won't cause white smoke, right?
What is wrong? If the compression is OK, shouldn't the head gasket be OK? What else will cause white smoke in the exhaust and loss of coolant so quickly? Could it be the turbo?
Please help...
Thanks again!
Jeff
Please help...
Thanks again!
Jeff
