I’m going to assume from the wording of your question that you have a manual 5 speed transmission, is that correct? If so just to get this out of the way first, you are aware that when attempting to put a vw into reverse you have to push down on the shift lever?
I ask that because I read the story of a guy who bought his first vw and drove around for about 3 months thinking he had no reverse until he finally figured it out.
There are 3 videos at the bottom of the page in this link that explain the whole linkage/bushing setup and shows you how to adjust it.
You might check to confirm but I believe the 98-99 New Beetle models; use the previous generation Mark III shfiter assembly and it is different, then the Mark IV 2000 model on type.
If this is the case; Dieselgeek, sells a different kit for the 1998-1999 VW New Beetle here:
There are many places; that sell rebuild kits for this earlier shifter and the bushings, that are part of other parts of the linkage. UROTUNING, has these and more parts for these here:
Ultimate shifter repair kit:
more parts; including a short shifter kit, as well:
Another part, that fails; is the stock plastic shifter carrier, you might upgrade to a steel upgraded version, which also is a short shifter upgrade as well:
249216
Here is a youtube video; going over the repair and rebuilding of the Mark III shifter assembly:
Many more videos:
