Has anyone been able to get the window regulator repair kit for the new beetle convertible installed? I have it all out of the car and threaded but I can not for the life of me get the white sprung piece to go reach enough to clear the spool housing. What is the trick? I am not a weak guy and I have wrestled this thing for hours to no avail. as a footnote I took care to leave the zip tie on it to keep the spool wound from the factory.
If it came from the parts store like that, it's defective. That white piece (with the spring and the pin you pull after installation) should have been attached to the big black center piece. Since I was going from memory, I did a quick web search and found pictures of the repair kit, so yea, you're going to have to try to return that part. Good luck!
