Basics: year (2004), model (convertible), engine type and trans type?
A non start could be a number of issues; a car needs a number of things to be correct, to successfully start: adequate fuel pressure, charged battery, ignition spark and compression.
A common issue with these cars, is the immobilizer can come on (usually a flashing light in the speedo cluster, this is the built security system); it will start for a couple of seconds and die.
A scan for trouble codes; may reveal, codes that may give you an idea, why the car won’t start.
Let us know, if the immo light is blinking, it starts, then stalls after a couple of seconds or if you are willing to try to fix the problem yourself or seek professional help, to diagnose the problem and complete needed repairs? (Do you have anyone to help you) or are you comfortable doing “diy” repairs? Thanks!
VW immobilizer technical information and problem troubleshooting
How to troubleshoot VW immobilizer and fix, bypass or detele the immo if car won't start or engine shuts off
www.myturbodiesel.com
