so i took the relay out and took it apart. noticed a little calcium deposit on the back of the board...nothing huge...cleaned it with alcohol and examined all parts. nothing is corroded or burnt out. still having the same problem. should i try one from a junker?
Ditto the bad relay, regardless of what you are seeing. Left unrepaired, you will ultimately have a wiper wear pattern in the windshield glass and it's rough on the wiper blades.
M.
