My Beetle decided not to start. I've eliminated any ignition (coil) or fuel pump problems. I found that the F10 fuse in the panel is blown. When I replaced it I did get the motor to fire up for a second, then it died. The fuse was blown again. Apparently, this is the main power to the ECM. Has anyone seen this problem? Does the ECM/ECU need to be replaced?
What year is your NB? Your profile says 2011 but there was no NB that year. I'm assuming its 2001?
