first timer here, Hello to all,
I have a 2000 GL 2.0 yellow her name is Betty that shut down while driving, It turns over but no fire, It is leaking antifreeze, not sure where, the timing belt turns while cranking so its not froze up, my question is if the water pump went out would this keep the car from starting ? or if it has a cracked block would that keep it from starting ? ( no bubbles or milk with oil) I replaced the crank sensor already ( no change) fuel pump pressurizes when door opens, I am replacing fuel pump relay and fuel filter this weekend, I have an inexspessive code reader, my 1st read after the shut down I got the following codes: P1582,P0506,P1128,P0102,P0121, My 2nd read after clearing and cranking was just one code P0341 witch by my book is the crank sensor, I ohmed pins 2 & 3 got 989 ohms, so it checks good, any help would be greatly appreciated,P.S. Low on funds to just be replacing parts to find out that does not work.
