I'm in need of the circuit board for a 98 beetle drivers side window. It's just a control board that I need, not the whole motor assembly.
If you have a burnt out motor I would bet your board is still in good shape!
shoot me a PM or post what you have for me, thanks!
Don't see much posting of failed motors, typically it is the DCM (door control module), which are very problematic, as apparently is the situation in your case. Try checking the part-outs on both here and over at www.vwvortex.com There are several running on both forums, but they are probably not going to come to you.
MORAV
