That Crazy Belgian Guy
I believe it only needs a different connector. Several tuner shops make harness kits that allow xenon units to fit into non-xenon cars.
-Des
Me Gusta!
Preston said:
why not just get the HID conversion?
Yeah, that would probably be the best way to go. Of course, it wouldn't be Bi-Xenons, so you'll have to put two sets in if you want to have Xenon Hi-Beams.
If you can win that auction for $250 or so and the seller ships to USA, I would say definately go for it, though. It would be much cooler to have Bi-Xenons and much cheaper than buying two $300 dollar kits.
As far as modifications need, I wouldn't think there shouldn't be a lot. Though, another thing I'm wondering is if the ballasts are mounted inside the headlight, because if not then you would have to get those too...
CRAZ4VW
Definitely not plug-and-play. Also, this auction doesn't include the ballasts/HID capsules/igniters that are required to operate the lights. Factor in those items as well and you're probably better off just going to a VW dealer and ordering the necessary parts. If you want more info on retro-fitting the Bi-Xenons, check out gt4237's thread, he did it on his NB.
CRAZ4VW
Nope, that's the leveling motor. On the New Beetle, the igniters and the ballasts are mounted separately from the headlights.
