My daughter's Beetle is giving me fits again. It is a 2000 . I put a headgasket on it about 6 months ago (and the usual other parts). It had the same problem then (prior to headgasket replacement) but something else seems to be the trouble now. Back then I replaced the front O2 sensor and coolant sensor. The car run well up to yesterday. Now it starts fine but give it any throttle and it dies above 2000 rpm (when floored). You can play with throttle and get it higher but it surges badly. If you hold the throttle at higher rpms, it has a rally bad sulphur smell out the exhaust and will completely die. I do not think the convertor is the problem. I had it off 6 months ago and was in mint condition inside. I replaced the fuel filter this morning. Did not help. Only codes were misfire codes and coolant sensors when this first happened. After clearing the codes and let it run, only codes are misfire codes (from when I was reving it up).
Thanks
Don
Thanks
Don
