Hey guys i know i have various threats already tackling many topics but i'm just trying to get this beetle upto par. So the other day i ran VDCS and got a almost long list of codes that the ECU returned. Crazy part is there has never been a check engine light which is weird. Could some of you experienced beetle owners help out a new beetle owner get this car together
Chassis Type: 1C - VW New Beetle
Scan: 01,02,03,08,15,17,19,22,25,26,29,35,37,39,46,54,56 ,65,75
------------------------------------------------------------------------------- Address 01: Engine Labels: 06A-906-032-AVC.LBL
Controller: 06A 906 032 A
Component: 1.8l 5VT NB AT G 3157
Coding: 00003
Shop #: WSC 00001
VCID: 1C4B57739FB3
12 Faults Found:
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incorrect. Correlation
(P1340) - 35-00 - -
16804 - Catalyst System; Bank 1: Efficiency Below Threshold
(P0420) - 35-00 -
16795 - Secondary Air Injection System: Incorrect Flow Detected
(P0411) - 35-10 - - - Intermittent
17535 - Fuel Trim; Bank 1 (Mult): System too Rich
(P1127) - 35-10 - - - Intermittent
17704 - Error in Mapped Cooling System <-------- Replaced thermostat which was bad and temperature sensor
(P1296) - 35-10 - - - Intermittent
17695 - Charge Pressure Control: Positive Deviation
(P1287) - 35-00 -
17544 - Fuel Trim: Bank 1 (Add): System too Lean
(P1136) - 35-10 - - - Intermittent
18010 - Power Supply B+ Terminal 30: Voltage too Low
(P1602) - 35-10 - - - Intermittent
17977 - Cruise Control Switch (E45): Implausible Signal
(P1569) - 35-00 -
18057 - Powertrain Data Bus: Missing Message from ABS Controller
(P1649) - 35-10 - - - Intermittent
17832 - Secondary Air Injection System; Bank 1: Leak Detected
(P1424) - 35-00 -
17965 - Charge Pressure Control: Positive Deviation
(P1557) - 35-10 - - - Intermittent
Readiness: 0000 1000
Coding: 00003
Shop #: WSC 00001
VCID: 1C4B57739FB3
12 Faults Found:
(P1340) - 35-00 - -
(P0420) - 35-00 -
(P1287) - 35-00 -
(P1569) - 35-00 -
(P1424) - 35-00 -
