This has been occuring for 3 weeks now. When I try starting my 1.9 tdi beetle it won't show the glow plug indicator light. If I switch the ignition on and off eventually it will appear and I hear the relays and the fuel pump. But If it doesn't show I hear none of that. Eventually I can get the car to start and it runs and drives smooth. But if I turn it off and let it cool down it becomes a nightmare to start. I changed the glow plugs and wiring harness. But it's still doing the same thing. the check engine light is on but only says my throttle body is going bad. But again once I get it to start I get perfect response and it drives smooth. I replaced all relays and still get the same result. Could the next thing I should check be the ECU. Any help would be very much appreciated.
