That vacuum sound, sounds like the SAI pump has lost it's seal. Next time you start your beetle cold, first pop your hood- you'll need to make a quick jaunt underneath the hood right after you start it. Start your beetle, then go under your hood and put your hand around the SAI pump. Imagine your SAI being an oreo cookie- 2 halves. You would be placing your hand around the middle section- the oreo filling. It's along this seam where you'll feel suction on your hand. If you feel this suction, your SAI pump has a bad seal. Matter of fact, you might see the white foam seal protruding out of the seam... so I guess my oreo analogy isn't too far off :lol:
if you're beetle is already warmed up, have someone in the car while you are under the hood, with your hand around the pump. have a person in the car rev up the engine several times. This should get the pump going & allow you to test for a seal leak.
The fix is very easy. Route out the loose rivets with a drill bit, replace the rivets with machine bolts & corresponding nuts. I did the diy via the thread here. Kinda hard to link it via my phone. When I get home, I'll post it for ya.
All the best to ya.
Sent from my SGH-T679 using AutoGuide App
