Recently I took my 2000 VW 1.8 Turbo to get it inspected prior to registration. It failed due to the following: When the car is put into Drive or 3rd gear, the check engine light comes on and generates a code stating there is a problem with the powertrain. Also, if it is put into Drive or 3rd gear, the gear/shift indicator shows as black blocks instead of the actual gear. When in Drive or 3rd gear, it won't go into overdrive...they are basically the same gears. It also won't start in Neutral. Any info would be appreciated. I've taken it to VW and they are basically incompitent. I'm also a 45+ year euro-mechanic but I'm not too familiar with the new bug.
