SRS, Airbags, crash sensor(s), seatbelts - after crash
8.3K views 4 replies 4 participants last post by  agnewsautos
#1 ·
Any advice on repairing the SRS system after a crash?
Both front air bags deployed and both seatbelts locked up!
I have searched the forums for info on restoring the SRS / airbag / seatbelt system but have not found any links on how to do it complete after an accident. Do I need to replace the crash sensors as well, if so where are they? Do you replace the complete seat belt set up or just the ballistic recoil / tensioner? Should I buy another air bag computer or just try to have mine reset?
#2 ·
You don't repair any of it. You simply remove and replace. Everything.
You might be able to save/reset the computer, but the sensors, the belts, tensionsers, etc, are all used up garbage now.
Good luck, sorry, I'm not sure where the sensors are located.
#3 ·
sensor location?
Thanks, anyone know where crash sensor(s) are located in a '99 NB? Is there just one in the computer on the floor under the dash or are they located behind the front bumper?? I read somewhere that some sensors are a gold plated ball in a tube with a magnet that will reset itself after a impact and do not need replacement if not physically damaged?
#4 ·
i have both front air bags and Air bag control module from my 00 2.0. ever have any of them been used. i also have the clock spring for the front wheel. only thing i no longer have is the seat belts since somebody in your position bought those off of me. if you want them let me know i can get them to you for pretty cheap.
if you locate the sensors i will find them on my bug and ship those to you to since i no longer have any use for them
