2010 beetle no crank no start
99 views 5 replies 4 participants last post by  gtagg.707
#1 ·
I have a 2010 Volkswagen beetle 2.5l AT. my current issue is no crank no start. I put in a good battery and same thing, took out the starter got it tested and came back bad, so i got a new one. Same thing no crank no start, then i replaced the starter relay and the ignition switch. With the same results no crank no start. Is there place i can check and the electrical connection what should be the voltage for the places. Ive replaced all related parts other than the neutral safety switch. Is it a problem not worth digging for or is it something ive missed
#2 ·
Have you scanned for codes? Any work done on the car recently?
