I have had various problems with the AC system in my 2000 Beetle GLS 2.0 in recent weeks. The system worked fine until suddenly the compressor stopped turning on and the cooling fans stopped working properly. I replaced the fan control relay and fixed a bad ground under the battery. This seemed to do the trick. Almost... I push the AC button on the dash and the cooling fans immediately start spinning and the compressor clutch engages and the middle of the compressor spins smoothly and the blower inside the dash blows properly. When I push the button again the compressor clutch disengages and the cooling fans slow down or turn off. Everything seems to work as it should. But even when the AC is switched on I GET NO COLD AIR FROM THE VENTS! I took it to a reputable AC shop and he pulled a vacuum and it held fine and he carefully measured and added EXACTLY the right amount of r134a. He said it initially started to cool at but only got to 50 degrees or so then it started to go backwards and get warm. Now even with the AC on and the clutch engaged and the compressor spinning it does not even begin to blow cold air. I checked the heater flap and it does not appear that any hot air is leaking through the vents. Besides, the AC coolant lines are not even getting cool. Maybe the compressor is shot and not generating enough pressure? Can you think of anything else that might possibly create these symptoms? Thank you for any help or guidance you can offer.
