How long do you suppose one can drive with a car that has a faulty evap canister?
79 views 3 replies 2 participants last post by  billymade
#1 ·
#2 · (Edited)
Tell us the basics, year, model, engine, and trans type of your VW; specifically what trouble code are you getting? What is the history of your problem and has the problem being diagnosed correctly?
The car can theoretically drive for years with this issue; that being said, an evap issue could affect The fuel trims, can impact fuel mileage negatively and if the car ever gets inspected for emissions testing, instantly fail an inspection check.
Evap system repairs, tend to not be terribly hard but diagnosing the problem and finding the part that is bad, can be. Having a VW scan tool like VCDS by ROSSTECH can enable evap testing and reading trouble codes, can hopefully, help narrow down the source of the problem.
#3 ·
I keep pretty detailed records on my car, this is everything minus the oil changes,brakes,tires, etc...
Car Info
2010 New Beetle
Gas / Automatic / 38,719miles (I don't drive very often - maybe 50 +/- miles once a week)
I'm in NC and they do require an emissions test, I can apply for a waiver due to cost/part availability. After a certain age, the car won't need an emissions test, just a 'safety check'
10/1/2025
Hendrick VW Concord
Miles: 38,719
Scanned Vehicle found fault 02403 Evaporative Emissions System Leak Detection Pump Sense Open/Circuit. Previous visit Part Still on Back Order No ETA.
Part 1. FP-Number: 1C0-201-797-N EVAPCANI
9/22/2025
Hendrick VW Concord
Miles:38,659
Check Engine Light Came on and weird whizzing noise
scanned found: Fault Code: P0411 - Secondary air injection system incorrect flow detection and Found Bad/Worn Roller
Result: Reconnected the hose line and cleared faults. Replaced tensioner roller by the crank pulley the reset operations.
Parts replaced: 07K-145-172-C Holder and 38314 Tensione
9/8/2025New Battery AAA
7/24/2024
Hendrick VW Concord
Miles: 36,436
Check engine light on
Scan vehicle and found fault code P2403 - Evaporative Emissions System Leak Detection Pump Sense Open/Circuit. Ran test plans and found the probable cause is the LDP.
7/25/2016Carolina Volks
Miles: 18467
Check engine light is one. ECL Fault traced, replaced bank 1/sensor, 1/oxygen sensor, cleared and test drove.
Parts: 1k0-998-262-P OXY Sen Kit
1/25/2014Carolina Volks
Miles 11831
CEL Found Wiring to LDP and N80 Valved Chewed.
Repaired wiring.
9/4/2013Carolina Volks
Miles: 10549
Found fuel line chewed. Replaced and cleaned fuel from engine. 1 1C0-133-986-AN Pipe
10/19/2010Carolina Volks
Miles: 1427
Gas gauge fluctuates while driving. SOP ordered new Fuel Pump to correct
