Why won’t these coolant flanges fit?
1.6K views 11 replies 3 participants last post by  billymade
#1 ·
#2 ·
The vw new beetle parts; can be totally different or have just a slight difference, compared to other 1.8T VW/Audi cars.
I can tell you which ones will work; let me know, if you want to discuss this further and let us know, which flanges you would like to change. Thanks.
#5 · (Edited)
So far, no one has reproduced the coolant flange off the head of the 1.8t for the new beetle in metal (billet ir cast). That being said, you could probably use the golf version and add extra length of hose to make it work, possibly modify it to add the missing connectors or add more, plus a "t" connector to connect to the single outlet.
To get a sense if the difference; between the new beetle and golf versions of this coolant flange, look at these links: (note the two vs one outlet on the bottom; possible overall increase in length/shape):
New beetle 1.8T: 06A121132AQ
https://www.google.com/search?q=06A121132AQ&ie=UTF-8&oe=UTF-8&hl=en-us&client=safari
Golf 1.8T: 06A121132AP
https://www.google.com/search?clien...p.3...6986.6986..7685...2.0..0.97.97.1......0....1j2.......8..35i39.l7TEWIohLXY
#6 ·
We have discussed having this part made in the past and i contacted USP Motorsports, WhanAB to no avail and gruvenparts was open to making a billet/tig weleded aluminum version but it required 20 prepaid orders @ almost $150 apiece:
https://www.newbeetle.org/forums/1-...1-gruven-parts-billet-aluminum-1-8t-coolant-flange-preorder.html#/topics/121201
For other plastic cooling parts; these are available and are the same for the new beetle 1.8T:
1. thermostat cooling flange (check) 034 Motorsports, Eurowise, ECS Tuning, WhanAB and many more cheap ones on ebay. (Works on 1.8T and 2.0L)
2. "y" pipe (check) 42DD and gruvenparts
3. cooling temp sensor cooling flange (not yet reproduced; specifically for the new beetle 1.8T) but WhanAB makes one for the 2.0L, plus a vendor ebay sells them as well.
4. heater core connectors: replacement billet or cast aluminum fittings.
So, there are some parts out there that work or some that could be made to work with add on hose and a t fitting.
#7 ·
Yea sorry, wasn’t paying attention to the two ports off the bottom. I think I’ll just see if I can get a Y adapter. Are the bottom ports the same size at least? Looks like 5/8 maybe, I’ll have to go look again, so I’m thinking a 5/8 T or Y and just connect those ports into one. Just don’t want to keep buying plastic junk when I can spend the money once and never worry about it. Thanks for all the info. I will probably be asking a lot haha.
#10 ·
Good question, best to look at exploded views on vw's parts site or online etka, to id rhe part and/or most parts have the part number imprinted on them:
www.parts.vw.com
http://www.oemepc.com
#12 ·
Lately, the cost of the cast aluminum copies of the plastic parts; have really come down, hopefully they will make a 1.8T VW New Beetle version for the coolant flange, that comes off the head.
$20-$40 (could be made to work with extra hose adapter/hoses, etc):
https://www.google.com/search?q=vw+...ast+aluminum+coolant+flange&aqs=chrome..69i57.8769j1j7&sourceid=chrome&ie=UTF-8
The problem with the plastic flanges; is not just the o-ring, cracked plastic but many times, they warp, which causes leaks as well.
