Sortly after buying my 2002 NB GLS TDI last month I noticed that the HVAC controls under the radio do not light up. They normally do, don't they?
Lnzbug, did you need pliers to pull out the fan control knob? My headlight switch came out easily when I replaced it with a Euroswitch. The fan control knob doesn't seem to want to come out that easily.Yes they do. You need to change the bulb that is located behind the fan control. Turn it to the second speed and pull the knob straight out.Cover the knob with a piece of rubber to protect it. (I used a jar opener gripper)
Use pliers & use something to protect the knob. That's why I used the jar gripper pad thingie(official nameLnzbug, did you need pliers to pull out the fan control knob? My headlight switch came out easily when I replaced it with a Euroswitch. The fan control knob doesn't seem to want to come out that easily.
Thanks.
Thanks for the info however if you can add some pic and make a tutorial it would help people like me.Yes they do. You need to change the bulb that is located behind the fan control. Turn it to the second speed and pull the knob straight out.Cover the knob with a piece of rubber to protect it. (I used a jar opener gripper) You need a piece of plastic tubing to pull the bulb straight out. I got 1/4 inch diameter vinyl tubing from menards($1). Push the tubing over the bulb then pull out. Bring it to the dealer and they'll know exactly which one to give you. They gave me one freeThe new bulb just gets pushed in with the tubing. Then put the control knob back in and you're good to go
Good luck. If I can do it anybody can.
I'll try to take a few pics tomorrow.Thanks for the info however if you can add some pic and make a tutorial it would help people like me.
thanks again..
Here's what I used, a #2721 bulb from Advance Auto. jasonwinters3 bought his from Advance:Lnzbug, I am so glad you posted this fix as I am having the same issue! I have a question though. Can you get the bulb at Autozone or Advanced Auto, and if so, any idea what the number is? The dealer is out of the way and the others quite close.
I bet the bulb is just loose. Try just seating it properly again.Has anyone had a problem with the a/c lights just working every now and then? Mine will come on randomly so I thought it was loose wiring somewhere? I checked the fuses and they seem to be all good? I don't think that the bulb could be blown if it comes on sometimes or can it?![]()
If it's the bulb behind the heater control knob, i put an orange one in and it was still red. This is because all the fitments that light up RED have a RED filter behind them. So how someone got theres BLUE i would love to knowMine just died...
I cant see the pics however of the blue LED. I am interested however. I planned on trying it out today.
Probably confusing purple with blue.If it's the bulb behind the heater control knob, i put an orange one in and it was still red. This is because all the fitments that light up RED have a RED filter behind them. So how someone got theres BLUE i would love to know![]()
