41 - 60 of 87 Posts
Wow, you are going all the way with the “breathing” on your 1.8T build and “no expense spared”! Only the best parts chosen! Nice! :)
Discussion starter · #42 ·
Little update :) I received a couple more interesting parts. Slowly getting there. Also, the beetle will be repainted next week in a different metallic color and it will get tinted windows.
The gearbox will be 02m 6speed instead of the 5speed I have right now and obviously new LSD differential and full set dog engagement 1-6.Complete rebuild of the gearbox.
Discussion starter · #43 ·
The thread name does not make sense at all anymore. Beetle get new color :)
Finally get new gearbox :) Full set 1-6 dog box monster performance 02m 6Speed fwd,Wavetrac lsd +arp bolds for the ring crown...Wavetrac comes without bolts for the crown ring and bearing...
Also, spend some money for Plex uSDM-102 OLED micro display. Amazing thing...It's very tricky to find some of these. If your looking for something like this, my recommendation.
Thank you everyone :) see you soon with new updates :D
Discussion starter · #47 ·
Got any body shots with things put back together? Things are really coming along; good work! :)
Hey man,thank you for checking...Probably your the only one who is interested for this topic and progress of my projects [emoji1787]
I ordered couple more main parts[emoji847]
Almost there
1. 871389-5004s Garrett g25-550 0.72 vband standard rotation external WG
2.Treadstone TR8C
3.787-2250-21-93C JE-Pistons PIN STRAIGHT WALL PIN 20 mm. 5.33mm wall 4x
4.Phenolic intake manifold spacer for the 1.8T large port
5.KW v3
I'll install kw v3 soon as they arrived and I'll share you couple photos....Rest od the things I,m working like wide body kit and everything else,will wait for now.I will not publish and progress related to that.
Sent from my Mi A3 using Tapatalk
Discussion starter · #48 ·
It's hard to find a nice and good single holder for a gauge for new beetle and I decided to make one. For the time I'm waiting for parts I did a prototype...It will be blended together and covered with Alcantara...
Also you can see in the background I'm working on wide fenders:)))Molding almost done for the rear fender and rear bumper...
Cheers
Discussion starter · #51 ·
I decided to build a stroker :D 2.0
Just bought FSI 2.0 Crankshaft and return my pistons...Waiting for the new ones...Couple more things and we are ready to build the engine...
In the meantime, I soda blast and pressure wash my AGU large port head.
Discussion starter · #52 ·
Quick update :)
I decided to swap g25-550 for g25-660 my initial goal is 500bhp and it will be much easier to achieve with the g25-660...Here is some update.
The head is polished and dimpling is done on intake side
AN20 welded to 034motorsport breather...Instead this
Discussion starter · #53 · (Edited)
OEM VW PARTS
waterPump 06A121012G
oilpump 06A115105B
oil filter bracket 06A115405BS
Oil dipstick 06A115611Q
Guide funnel 06A103663B
Roller chain 06A115125B
Suction pipe 06A115251
AUDI TT 20V MOT APX - CTVW008
Catcams 1013665
Sytec Uprated 300 ltr/hr In Tank 1.8T Fuel Pump 2WD - Syt410G
CSF RACE RADIATOR FOR 99-06 VW GOLF/GTI, 99-06 VW JETTA/GL
Bottom adapter set for EV14 injectors with long spray end
Nord-Lock NL10SP, Nord-Lock NL20SP
ELRING 292.011 Gasket Set, crankcase
2.0L TFSI BILLET RACE Timing Belt Gear 2.0L
TFSI EA113 Fluidampr Crank Pulley Fluidampr
JE 1.8t Forged Pistons TFSI 92.8mm Stroke
1.8t 2.0T FSI Oil Squirter Jet (Sold individually)
2.0 TFSI EA113 Diamond crank pulley washer
Oil cooler Pro Line Series 9 50-910-7612
AN-10 (AN10) Banjo Adapter M22x1.5
1 x 1.8t Supertech valve spring kit SPRK-Audi 18T SPRK-AUDI18T
12 x 1.8t Supertech Inlet Valves single groove AIVN-1103S
8 x 1.8t Supertech Inconel Exhaust Valves single groove AEVI-1103S
40 x 1.8t Supertech single groove valve keepers/locks for 6mm stem KPR-6S-7
20 x 1.8t Supertech valve guide GDE-AU18T-10 1
Discussion starter · #54 ·
Here is the list of some other parts I don't have a photo...
MAHLE ORIGINAL TX 14 87D cooling water thermostat
ELRING 366.670 headgasket
ELRING 148.190 Gasket, exhaust manifold
ELRING 633.350 gasket set, cylinder head cover
ELRING 235.620 Seal Kit, valve stem
ELRING 893.889 Sealing ring, injector
ELRING 863.590 Gasket, timing chain tensioner
ELRING 133.205 oil drain plug seal cooper
NGK BKR8EIX
Ignition Coilpacks NGK
MAHLE ORIGINAL Spacer, crankshaft/Thrust Washer
12x INA Hydraulic Lifter - Inlet 058 109 309 F
8x INA Hydraulic Lifter - Exhaust 058 109 309 E
Alot of an fittings...
Steel rubber hoses AN4,AN6 AN 10
custom 3d printet hose separator...Let me know if you need 3d model...Exclusivly for the trunk,under the car and inside the car,for the under the hood I prefer aluminium instead of plastic...
Oil sump
Making custom stretch gauge
1.8T & S4 2.7T Hemi Upgrade throttle body 80mm
KW v3
41 - 60 of 87 Posts
